I downloaded and copied c4dpy to my cinema 4d folder. Then I run c4dpy.exe in a command file. But it seems to crash. What am I doing wrong? I tried downloading different versions of c4dpy.
Isn't there a path to set?
You are using R20.038. Current c4dpy is 20.057. Maybe here's your mismatch?
Hi @pim,
c4dpy needs to match the exact same version than Cinema 4D otherwise it crashes. Moreover, it is not updated when Cinema 4D update.
I agree that a proper error handling will be better and I've reported it to the development team. Cheers, Maxime.
Ok, I will give it a try and let you know. Thanks.
