I've been looking all over for Python documentation for STEP file imports for a few days, and haven't come across any solid info yet. Has anyone else found where this information might be found? Thanks!
Edit: I'm trying to import STEP files with specific settings as to not create a prompt window that usually happens when importing STEP files.
Hello Telerak,
here's an example for the OBJ Import: https://github.com/PluginCafe/cinema4d_py_sdk/blob/master/scripts/FileImportExport/import_OBJ.py You may want to adapt the code for STEP import.
Cheers, Robert
Hi @Telerak, first of all, welcome in the plugincafe community. Just a little request for your next topics, please mark your topic as a question see , I've done it this time, no worry at all.
You can find an example of the step file import bellow.
""" Copyright: MAXON Computer GmbH Author: Maxime Adam Description: - Import STP/STEP with custom settings. Class/method highlighted: - c4d.plugins.FindPlugin() - MSG_RETRIEVEPRIVATEDATA - c4d.documents.MergeDocument() Documentation: - https://developers.maxon.net/docs/Cinema4DPythonSDK/html/consts/FORMAT_export.html - https://developers.maxon.net/docs/Cinema4DCPPSDK/html/_fcadimport_8h.html Compatible: - Win / Mac - R20 """ import c4d def main(): # Retrieves a path to load the imported file selectedFile = c4d.storage.LoadDialog(title="Load File for STEP Import", type=c4d.FILESELECTTYPE_ANYTHING, force_suffix="step") if not selectedFile: return # Retrieves STEP import plugin plug = c4d.plugins.FindPlugin(c4d.FORMAT_STEPIMPORT, c4d.PLUGINTYPE_SCENELOADER) if plug is None: raise RuntimeError("Failed to retrieves the STEP importer.") data = dict() # Sends MSG_RETRIEVEPRIVATEDATA to OBJ import plugin if not plug.Message(c4d.MSG_RETRIEVEPRIVATEDATA, data): raise RuntimeError("Failed to retrieves private data.") # BaseList2D object stored in "imexporter" key hold the settings stepImport = data.get("imexporter", None) if stepImport is None: raise RuntimeError("Failed to retrieves BaseContainer private data.") # Defines the settings stepImport[c4d.CADIMPORT_SPLINES] = False stepImport[c4d.CADIMPORT_ORIGINAL_UNITS] = False # Sets the data by Scaling 10x and set to mm units scale = c4d.UnitScaleData() scale.SetUnitScale(10, c4d.DOCUMENT_UNIT_vMM) stepImport[c4d.CADIMPORT_SCALE] = scale # Finally imports without dialogs if not c4d.documents.MergeDocument(doc, selectedFile, c4d.SCENEFILTER_OBJECTS | c4d.SCENEFILTER_MATERIALS, None): raise RuntimeError("Failed to load the document.") c4d.EventAdd() if __name__ == '__main__': main()
Finally, you can find symbols for importer/exporter in FORMAT EXPORT page. Unfortunately, for options you have to search the C++ documentation, here the ones for STEP file Fstepimport.h as you can see it is not that much here, but if you take a look at the res files (Cinema 4D R20\resource\modules\cadexchange\description\Fstepimport.res) it also include Fcadimport resource so, that means you can also define the value from Fcadimport.h
I know the documentation get room to be improved on this topic. I will see what's possible to do. Cheers, Maxime.
Just want to add: You can also drag the import settings parameters from the preferences dialog to the python console, so the symbol names show up there.
Edit @m_adam: For more information see Python Console - Drag and Drop.
@mp5gosu @m_adam I'll test out these options and see how it works out. Thanks for the information guys, I appreciate it!
