On 26/03/2003 at 09:52, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.012 Platform: Windows ; Mac ; Mac OSX ; Language(s) : C.O.F.F.E.E ;
--------- My first little plugin is mostly done, there's one little thing that I've worked around:
Currently I've the following code in the plugin's GetState() method:
var doc =GetActiveDocument(); if (!doc) return NULL; var obj =GetActiveObject(doc) ; if (!obj || !instanceof(obj, PolygonObject)) return NULL; var polysel = obj->GetPolygonSelection(); if (!polysel||polysel->GetCount()==0) return NULL; return CMD_ENABLED ;// ok, enable
This enabled the plugin when there is a polygon selection.
However, to prevent excessive flashing of the icon I actually I would like to enable the plugin when the editor is in polygon mode, not only when I actually have a selection.
Any hints?
Thanks a lot in advance!
Kabe
On 28/03/2003 at 10:36, xxxxxxxx wrote:
doc->GetMode() == [CODE]Mpolygon
[/CODE]
On 28/03/2003 at 10:50, xxxxxxxx wrote:
Mh, you realized that I was asking about COFFEE?
Unfortunately that function is neither in the docs [which would be bearable] nor avalailable in the application [(9) Member not found].
I'm using R8.1 with OS X
Thanks for any clarification!
Klaus
On 28/03/2003 at 10:55, xxxxxxxx wrote:
Sorry, then it's not possible.
