SOLVED How to check if a spline is a freehand spline?
By "freehand" spline, I mean, not a primitive, like Star or Circle.
So, any spline that is converted into an editable spline or imported from an EPS ou Illustrator file would be considered a "freehand" spline.
My problem is that:
is_spline = bool(info & c4d.OBJECT_ISSPLINE)
will return True for ALL splines, wether they are parametric or editable splines.
How can I differentiate between them?
Ok, found a solution.
I checked for:
is_spline = spline.IsInstanceOf(c4d.Ospline)
And, if False, it is a parametric primitive.
I checked for:
I just want to add that an example on how check a spline can be found in the BaseObject Manual.
best wishes,
Sebastian
