Python: Key Error while initializing GUI, Dictionary, self
"Dictionary" "self" and old SDK sample code might be my issue, but can somebody help me and point out, why I get a key error by just adding more gui elements to this old SDK ToolData plugin liquid-painter sample code.
adding a Checkbox (Bool) worked, but adding other gui elements breaks the smaple code somehow.
Key error on line 39 & 107 (marked in the Code so you don't need to search)
Thanks in advance
R20 Visualiceimport c4d import os from c4d import gui, plugins, bitmaps # be sure to use a unique ID obtained from www.plugincafe.com PLUGIN_ID = 1015073 # for GeLoadString values must match with the header file IDS_PRIMITIVETOOL = 50000 class SettingsDialog(gui.SubDialog): parameters = None def __init__(self, arg): self.parameters = arg def CreateLayout(self): self.GroupBegin(id=1000, flags=c4d.BFH_SCALEFIT, cols=2, rows=5) self.GroupBorderSpace(1, 1, 1, 1) # Bool self.element = self.AddStaticText(id=2003, flags=c4d.BFH_SCALEFIT, initw=1, name="Extend Vector: ", borderstyle=c4d.BORDER_NONE) self.element = self.AddCheckbox(id=2002, flags=c4d.BFH_SCALEFIT, initw=1, inith=0, name="") #valuebool = self.parameters['extend_vector'] self.SetBool(2002, False) # Extension Value self.element = self.AddStaticText(id=3001, flags=c4d.BFH_SCALEFIT, initw=1, name="Extension Ratio: ", borderstyle=c4d.BORDER_NONE) valueextension = self.parameters['extension_ratio'] self.AddEditSlider(id=3002, flags=c4d.BFH_SCALEFIT) self.SetFloat(id=3002, value=valueextension, min=0.1, max=100, step=0.1, min2=0.0001, max2=1000, quadscale=True) print self.parameters self.element = self.AddStaticText(id=1001, flags=c4d.BFH_SCALEFIT, initw=1, name="Sphere Size: ", borderstyle=c4d.BORDER_NONE) valuespheresize = self.parameters["sphere_size"] # first key error self.AddEditNumberArrows(id=1002, flags=c4d.BFH_SCALEFIT) self.SetFloat(id=1002, value=valuespheresize, min=0, max=20) self.GroupEnd() return True def Command(self, id, msg): if id == 1002: self.parameters['sphere_size'] = self.GetFloat(1002) print "Sphere Size: ", self.GetFloat(1002) if id == 2002: self.parameters['extend_vector'] = self.GetBool(2002) print "Extend Vector:", self.GetBool(2002) if id == 3002: self.parameters['extension_ratio'] = self.GetFloat(3002) print "Extension Ratio: ", self.GetFloat(3002) return True class AVTTool(plugins.ToolData): # Inherit from ToolData to create your own tool def __init__(self): self.data = {'sphere_size': 15} self.data = {'extension_ratio': 1} def GetState(self, doc): if doc.GetMode() == c4d.Mpaint: return False return c4d.CMD_ENABLED def Debug(self, msg): # c4d.CallCommand(13957) # Konsole loeschen print "Konsole geloescht." return True def KeyboardInput(self, doc, data, bd, win, msg): key = msg.GetLong( c4d.BFM_INPUT_CHANNEL ) cstr = msg.GetString( c4d.BFM_INPUT_ASC ) if key == c4d.KEY_ESC: # do what you want print "ESC Key Pressed." # return True to signal that the key is processed return True return False def MouseInput(self, doc, data, bd, win, msg): mx = msg[c4d.BFM_INPUT_X] my = msg[c4d.BFM_INPUT_Y] device = 0 if msg[c4d.BFM_INPUT_CHANNEL] == c4d.BFM_INPUT_MOUSELEFT: device = c4d.KEY_MLEFT elif msg[c4d.BFM_INPUT_CHANNEL] == c4d.BFM_INPUT_MOUSERIGHT: device = c4d.KEY_MRIGHT else: return True null = c4d.BaseObject( c4d.Ometaball ) null[c4d.METABALLOBJECT_SUBEDITOR] = 10 null.MakeTag( c4d.Tphong ) doc.AddUndo( c4d.UNDO_NEW, null ) doc.InsertObject( null ) doc.SetActiveObject( null ) c4d.DrawViews( c4d.DA_ONLY_ACTIVE_VIEW | c4d.DA_NO_THREAD | c4d.DA_NO_ANIMATION ) rad = self.data['sphere_size'] # second key error dx = 0.0 dy = 0.0 win.MouseDragStart( button=device, mx=int( mx ), my=int( my ), flags=c4d.MOUSEDRAGFLAGS_DONTHIDEMOUSE | c4d.MOUSEDRAGFLAGS_NOMOVE ) result, dx, dy, channel = win.MouseDrag() while result == c4d.MOUSEDRAGRESULT_CONTINUE: mx += dx my += dy # continue if user doesnt move the mouse anymore if dx == 0.0 and dy == 0.0: result, dx, dy, channel = win.MouseDrag() continue cl = c4d.BaseObject( c4d.Osphere ) cl.SetAbsPos( bd.SW( c4d.Vector( mx, my, 500.0 ) ) ) cl[c4d.PRIM_SPHERE_RAD] = rad cl.InsertUnder( null ) c4d.DrawViews( c4d.DA_ONLY_ACTIVE_VIEW | c4d.DA_NO_THREAD | c4d.DA_NO_ANIMATION ) result, dx, dy, channel = win.MouseDrag() if win.MouseDragEnd() == c4d.MOUSEDRAGRESULT_ESCAPE: doc.DoUndo( True ) c4d.EventAdd() return True def GetCursorInfo(self, doc, data, bd, x, y, bc): if bc.GetId() == c4d.BFM_CURSORINFO_REMOVE: return True bc.SetString( c4d.RESULT_BUBBLEHELP, plugins.GeLoadString( IDS_PRIMITIVETOOL ) ) bc.SetLong( c4d.RESULT_CURSOR, c4d.MOUSE_POINT_HAND ) return True def AllocSubDialog(self, bc): return SettingsDialog( self.data ) # always return new instance if __name__ == "__main__": bmp = bitmaps.BaseBitmap() dir, file = os.path.split(__file__) fn = os.path.join(dir, "res", "AligntoVector.tif") bmp.InitWith(fn) plugins.RegisterToolPlugin( id=PLUGIN_ID, str="Py-AlignToVector", info=0, icon=bmp, help="Select two Points to generate a Vector. Then Click additional points to move them onto the Vector.", dat=AVTTool() )
as always, please use the Q&A system and also tell us the version of Cinema 4D you are using.
There is no issue with adding GUI elements. The issue is with these lines of code:
Please make sure you understand how to use a Dictionary in Python.
best wishes,
Sebastian
Thanks Sebastian,
I did read your dictionary link but was wondering why then this code works in the sample sdk
what i've tried so far to set or read the dic. in the init
self.data["sphere_size"] = 15 self.data["extension_ratio"] = 1 self.data.get("sphere_size") self.data.get("extension_ratio") self.data = parameters["sphere_size"] = 15 self.data = parameters["extension_ratio"] = 1 self.data = parameters.get("sphere_size") self.data = parameters.get("extension_ratio") self.data = {'sphere_size': 15} # original SDK Code ! self.data = {'extension_ratio': 1}
This is obviously a problem of myself understanding the concept of "self" but I really like to learn by solving c4d problems instead of generic Phyton lessons.
kind regards mogh
R20 Visualize
this isn't a Cinema 4D issue; it has also nothing to do with "self". It is just about understanding basic Python syntax.
Just run this code
someDict = { "a", 1} someDict = { "b", 2} print(someDict)
to see that it only contains one key/value pair. This is because the second line does not add a key/pair value. The assignment operator overwrites the variable with a new Dictionary.
I strongly recommend do to some generic Python lessons.
best wishes,
Sebastian
thanks solved:
self.data = {'sphere_size': 15, 'extension_ratio': 1, 'extend_vector': False}
kind regards
