Hi!
Opening a GeDialog with -2 as xpos/ypos opens it in the center of the primary screen. Is it possible to open the dialog on whichever screen the Cinema 4D window ist currently?
Thanks!
Hi Boony2000, thanks for reaching out us.
With regard to your question, it's currently not possible to specify on which monitor a GeDialog should open by default.
It's worthy also noting out that the way the windowing system in Cinema 4D has been designed, beside giving the user the freedom to properly place a GeDialog in any screen, guarantees that, once the dialog has been positioned and layout saved, it will re-appear on the proper screen as soon that layout will be loaded again.
Best, Riccardo
Ok, thanks!
