Hi everyone,
I have released a plugin I use to create documentation for my plugins.
The plugin is free. Currently available for R20 for Windows. I will add an OSX version if people ask for it.
https://www.plugins4d.com/docs
If you use it for anything let me know. Also if you have any features requests then send them my way.
Cheers, Kent
Hi Kent Interesting. I'd like to test it, but I'm on Mac Is it compatible with versions prior to R20?
Really cool Kent! Thank you for sharing.
For Show Help, I could include a separate library to pop up a help dialog with the correct page, I already have it implemented in my other plugins. But if you wish to pop up your own dialog, or just launch a browser with the link, you can add the ID of the page to the end of the index.html?id=SECTIONID
So something like this: https://help.plugins4d.com/?id=1026
You can get the id for a page by right clicking on the section and choosing "Copy ID To Clipboard".
I will add in your feature requests to my list.
OSX will be coming later on. At the moment I am only support R20 since its a free plugin, so don't have the time/resources to put into it.
I just updated the plugin to include the Alt-Text for command icons.
When you drag and drop a command into the DropZone and then paste your text into the section you will get something like this...
![Add Doodle Frame][COMMAND_1022215]
It will look like this in the HTML code when published...
<p><img src="images/COMMAND_1022215.png" alt="Add Doodle Frame"/></p>
Very usefull plugin! Thanks!
Hi Kent,
thanks for sharing this!
Cheers, Andreas
I'm trying to use this super handy plug-in to build help system for my plug-ins. Thanks for sharing this! After some days of working i have a some suggestions and bug reports.
