hey,
i got a spline tool which is unsing the ISSPLINE and GENERATOR flag.
if i set a matrix object mode to anything exept vertex it generates points accordingly to the choosen distribution mode.
if i convert the spline generator to an actual spline the vertex distribution works well.
Hi Pyr,
I've tried with a very basic spline generator and the clones are properly created under all "distribution" modes.
Here's the plugin responsible for generating the curve:
import math import c4d from c4d import plugins, utils PLUGIN_ID = 99911332 class SDKSupport_11332 (plugins.ObjectData): def Init(self, node): return True def GetContour(self, op, doc, lod, bt): rad = 200 sub = 3 TANG = 0.415 op = c4d.SplineObject(sub, c4d.SPLINETYPE_BEZIER) if not op: return None for i in xrange(sub): sn, cs = utils.SinCos(math.pi*i/float(sub-1)) op.SetPoint(i, c4d.Vector(cs*rad,sn*rad,0.0)) vl = c4d.Vector(sn*rad*TANG,-cs*rad*TANG,0.0) vr = -vl op.SetTangent(i, vl, vr) op.Message(c4d.MSG_UPDATE) return op if __name__ == "__main__": plugins.RegisterObjectPlugin(id=PLUGIN_ID, str="SDKSupport_11332", description="SDKSupport_11332", g=SDKSupport_11332, info=c4d.OBJECT_GENERATOR|c4d.OBJECT_ISSPLINE, icon=None)
Can you provide some further detail on your spline generator?
Cheers, Riccardo
Ok this was defently my fault. It works now. I was using GetVirtualObjects instead of GetContour.
