Plugin OnFloor 1.1.0
Hello
This plugin is a tool that allows you to place one or more objects on the floor.
The use is very simple:
Select the tool, then click on each object you want to put on the floor.
You can specify the level at which you want to place the objectIf this tool is useful by you, or if you find a bug ;) Let me know.
For Cinema4D R14, R15, R16, R17, R18, R19, R20:
OnFloor
For Cinema4D R13 :)
OnFloor_R13
thank you for sharing your work!
best wishes,
Sebastian
Thank you Sebastian ;)
And thanks to those who helped me on this forum, and who allowed me to finalize this plugin :)I would probably have a lot more questions, because I started a plugin for the creation of a road network (a little like House Builder)
This post is deleted!
Thanks to all the testers,
this plugin is therefore Cinema4D compatible:
There is also a version compatible with R13Enjoy ;)
How to use this tool with objects grouped in a single null?
Not working with Figure primitive:
Traceback (most recent call last): File "C:\Users\user\AppData\Roaming\MAXON\Cinema 4D R20_4FA5020E\plugins\OnFloor_1.0.0\OnFloor\OnFloor.pypv", line 108, in MouseInput File "C:\Users\user\AppData\Roaming\MAXON\Cinema 4D R20_4FA5020E\plugins\OnFloor_1.0.0\OnFloor\OnFloor.pypv", line 47, in CenterAxe File "C:\Users\user\AppData\Roaming\MAXON\Cinema 4D R20_4FA5020E\plugins\OnFloor_1.0.0\OnFloor\OnFloor.pypv", line 24, in MoveAxe ValueError: Invalid object length.
Just in case. Using my Target4D plugin you can drop your object to any surface
Thanks for report @mikeudin
Bug fixed, links updated
Plugin updated.
minor bugfix
Update 1.1.0
