FormatStatement and maxon DataTypes...
Is there any information available on how the Maxon DataTypes implement
ToString()
's FormatStatement?
And secondly, amaxon::Data
withnullptr
as argument gives a different result than an unconfiguredFormatStatement
argument. Is this intended behaviour?// Store values template <typename T> void CreateAttribute(maxon::String name, T value) { _attributes.Set(name, value); } // ........ myElement->CreateAttribute("MyAttributeName"_s, 23.0);
// To print them: maxon::String buf; maxon::FormatStatement fs; buf += " "_s + attrib.first.ToString(nullptr) + "=\""_s + attrib.second.ToString(nullptr) + "\""_s; // This gives another result than //buf += " "_s + attrib.first.ToString(nullptr) + "=\""_s + attrib.second.ToString(fs) + "\""_s DiagnosticOutput("@", buf);
there is no information available on how a specific data type implements
ToString()
. You can find the implementation of some data type's ToString() function in the corresponding header for source file in the framework.Could you explain your second question a bit more? What data exactly is stored in
maxon::Data
? What is stored inattrib.second
?General information on data types and FormatStatement is available in these manuals:
If you want to combine strings as show in your code you can also use
FormatString()
. See String Manual.best wishes,
Sebastian
Hey Sebastian,
thanks for
@s_bach said in FormatStatement and maxon DataTypes...:Could you explain your second question a bit more? What data exactly is stored in maxon::Data? What is stored in attrib.second?
Sure. I'm storing a key value pair of maxon::String and a variable type (Float, String, Int, Vector, etc.).
for example:maxon::DataDictionary dict; dict.Set("MyKey"_s, maxon::Float(3.0)); // or simply dict.Set("MyKey"_s, 3.0) // and so on...
After that I'm iterating the dictionary and use DiagnosticOutput for printing to IDE console:
for (const auto& data: dict) { DiagnosticOutput("Key: @ / Value: @"_s, data.first.ToString(nullptr), data.second.ToString(nullptr) // If I replace the nullptr here with a dummy FormatStatement, the output changes from `3` to `3.000` }
I don't understand why the nullptr gives a different result than with given an empty FormatStatement?
By the way, thanks for pointing me to FormatString (didn't know about that one), that's very helpful. :)
edit: One of the reasons I'm asking this, is because in case of a vector,
ToString
outputs something like(3.0, 2.5, 11.6)
- note the braces.
I wanted to know if there are some identifiers available that change the output, therefore my initial question. Searched the headers already, no success. :)
I can only assume that somewhere deep inside Cinema there is a switch that formats the output depending on the given FormatStatement argument.
If you want to format a value manually, there are many conversion functions: Conversion
You can use maxon::String::FloatToString() to define how a float value is formatted.
The implementation of a vector's ToString() function can be found in the
vec.h
header file:String ToString(const FormatStatement* formatStatement) const { return "("_s + maxon::ToString(x, formatStatement) + ","_s + maxon::ToString(y, formatStatement) + ","_s + maxon::ToString(z, formatStatement) + ")"_s; }
best wishes,
Sebastian
Ah, thank you. I didn't take a look at
vec.h
Meanwhile, I already wrote a conversion unit to handle all sorts of formatting. Thought, it was possible to modify the intern string conversions somehow. But nevermind, all works pretty well. :)Cheers,
Robert
