Seperators in GetSubContainer
Hi again!
I am still messing around with custom menus. Is it possible to add any kind of seperator inside a submenu?
Trying to insert a seperator inside GetSubContainer doesn't do anything.I am trying to do something like the redshift menu has.
Or do the seperators here mean that the grouped entries are seperate commandData Plugins?
A workaround might be to add disabled entries that display a line by naming them
"----------&d&"
Is there documentation on stuff like&d&
or[name]&i[iconID]&
? Finding these nuggets of wisdom by chance in random forums is not a very efficient way to figure out stuff.
Hi @Boony2000
In a GetSubContainer, to insert a separator use
InsData(0, "")
The ID used should always be 0. As described in ShowPopupDialog Example.Which give us
def GetSubContainer(self, doc, submenu) : menuItems = [["name1"], ["name2", "hasIcon"], ["name3"]] for i, data in enumerate(menuItems) : if len(data) > 1: submenu.SetString(i+1000, data[0] + "&i" + str(c4d.IDM_KEY_NEXT) + "&") submenu.InsData(0, "") else: submenu.SetString(i+1000, data[0]) return True
