Hello, I have created this listview (I found it easier than a treeview and it makes what I need) but instead of having checkbox using(LV_COLUMN_CHECKBOX) or buttons (LV_COLUMN_BUTTON) I would like to have bitmap button. I saw that there was LV_COLUMN_BMP for bitmap but I do not know if that will help me and how. Is there any way I can use something like a bitmap button where I can use icons or images on it for this case. I would really appreciate if you would offer me an example if such a thing can be done. Thank you in advance.
Hi @Ogers LV_COLUMN_BMP accept an icon id. You can also register your own icon (meaning you own bitmap) with RegisterIcon from the Icon Librabry.
Note a ListView offer limited support if you want to directly draw into cells you will need to switch to a TreeView.
Here an example for handling LV_COLUMN_BMP .
#include "customgui_listview2.h" class ListViewDialog : public GeDialog { private: SimpleListView listview; Int32 GADGET_LISTVIEW = 10001; public: virtual Bool CreateLayout(); virtual Bool InitValues(); virtual Bool Command(Int32 id, const BaseContainer& msg); }; Bool ListViewDialog::CreateLayout() { // first call the parent instance Bool res = GeDialog::CreateLayout(); // Create the LisTView AddListView(GADGET_LISTVIEW, BFH_SCALEFIT | BFV_SCALEFIT, 0, 0); listview.AttachListView(this, GADGET_LISTVIEW); return res; } Bool ListViewDialog::InitValues() { // first call the parent instance if (!GeDialog::InitValues()) return false; // Define our Columns BaseContainer layout = BaseContainer(); layout.SetInt32('chck', LV_COLUMN_CHECKBOX); layout.SetInt32('name', LV_COLUMN_TEXT); layout.SetInt32('bttn', LV_COLUMN_BUTTON); layout.SetInt32('bmp', LV_COLUMN_BMP); listview.SetLayout(4, layout); // Fill our columns with 2 Entry BaseContainer data = BaseContainer(); for (Int32 i = 0; i < 2; i++) { data.SetInt32('chck', true); data.SetString('name', "Something"_s); data.SetString('bttn', "..."_s); data.SetInt32('bmp', IDM_KEY_LAST); listview.SetItem(i, data); } // Update the listView listview.DataChanged(); return true; } Bool ListViewDialog::Command(Int32 id, const BaseContainer& msg) { // If there is an action on our ListView if (id == GADGET_LISTVIEW) { // Check the column, if it's an action on the int(bmp) column ID Int32 ColId = msg.GetInt32(LV_SIMPLE_COL_ID); if(ColId == 'bmp') { // Retrieves all data of this lines Int32 itemId = msg.GetInt32(LV_SIMPLE_ITEM_ID); BaseContainer bc; listview.GetItem(itemId, &bc); // Get the current data of our int(bmp) column / BaseContainer Int32 currIconId = bc.GetInt32('bmp'); switch(currIconId) { case IDM_KEY_LAST: bc.SetInt32('bmp', Osphere); break; case Osphere: bc.SetInt32('bmp', IDM_KEY_LAST); break; default: bc.SetInt32('bmp', IDM_KEY_LAST); break; } // Push back our change to the item listview.SetItem(itemId, bc); // Update the ListView listview.DataChanged(); } } return true; }
If you have any question left, please let me know. Cheers, Maxime.
Hello @m_adam Thank you for your answer. I was looking more to have a bitmap button on my listView instead of just an icon, like a toggle button where the icon is changed when clicked. I have done it but not inside a listView. Is that possible to be done inside the listView. Thank you.
@ogers said in Adding Bitmap Button to ListView:
It's exactly what the code I posted does. Take a look at the Command method.
Thank you @m_adam It works fine
