Hello.
Is it possible to add Data on a TreeView using Layout files. If it is can you help me with an example please?
Thank you.
Solved TreeView Add Data
Hi Ogers, unfortunately, it's not possible to fill data of a TreeView using Layout File.
A Layout File does not have purpose to define value, but only information about how your object will be represented. So you can only state there is a CUSTOMGUI_TREEVIEW.
Then if you are in:
- NodeData, override GetDDescription method. See GetDDescription() Manual.
- GeDialog, override CreateLayout method. See GeDialog Resources Manual
If you have any questions, please let me know.
Hey @m_adam
But how can I add my own parameters on a TreeView.
I have created a CUSTOMGUI_TREEVIEW and have attached TreeViewFunctions and I know that we should modify functions overridden from the TreeViewFunctions but I do not know how to put my own parameters on the TreeView.
I have seen the example on the sdk too, with the activeobject but it seems a bit complicated.
Can you help me with this one please?
Thank you.
Hi @Ogers, first of all I did forget to mention in my first post, but could you read How to post questions and especially tagging, in order to know at least if it's a python or C++ question.
With that's said regarding your issue.
What do you mean by your own parameter?
I suggest you to read this topic, where I did a quick presentation about what to override, why and how.
https://plugincafe.maxon.net/topic/10654/14102_using-customgui-listview/2
If you have any question left please do not hesitate to come back with some code! :)
Maxime
