Use maxon::StringDecodings::Utf8()
std::string SceneParser::GetIDString(BaseList2D* node){ Int memsize=0; const Char* mem; node->FindUniqueID(MAXON_CREATOR_ID, mem, memsize); String ID_STR; ID_STR.SetCString(mem,memsize); std::string result=StringToStdString(ID_STR); return result;
Hello. I have this function but when I try the debugger it breaks showing this
DebugStop("Undefined encoding. Use maxon::StringDecodings::Utf8()");
The Debugger Stops in this line "ID_STR.SetCString(mem,memsize);" which is a function of c4d_string.h from the framework.
I understand what the error is but I am not finding the proper way to use "maxon::StringDecodings::Utf8()" so the function will work properly later. Is there any way I can fix this problem.
Thank you in advance!
Hi Ogers, thanks for reaching us.
With regard to your request, it's enough to pass the STRINGENCODING::UTF8 but I warmly suggest you to move from old string and use the maxon::String since the old implemetation just relies on the maxon::StringInterface::SetCString() method.
Last but not least consider that you can initialize both a String or maxon::String directly by passing a Char* (see respectively here and here)
For the sake of completeness, please find below a short snippet showing how to properly use SetCString()
#include "maxon/stringencoding.h" maxon::Result<void> TestOnCString(BaseDocument *doc) { iferr_scope; if (!doc) return maxon::IllegalArgumentError(MAXON_SOURCE_LOCATION); Int memsize = 0; const Char* mem; // try to find something meaningful if (doc->FindUniqueID(MAXON_CREATOR_ID, mem, memsize)) { String c4dStr; c4dStr.SetCString(mem, memsize, STRINGENCODING::UTF8); DiagnosticOutput("c4dStr: @", maxon::String(c4dStr)); } // add a more meaningful string const Int mysize = 5; const Char chars[mysize] = "MyID"; const Int myID = 12345; doc->AddUniqueID(myID, chars, mysize); if (doc->FindUniqueID(012345, mem, memsize)) { maxon::String maxonStr; const maxon::StringDecodingRef& stringDecoding = maxon::StringDecodings::Utf8(); maxonStr.SetCString(mem, memsize, stringDecoding) iferr_return; DiagnosticOutput("maxonStr: @", maxonStr); } return maxon::OK; }
Best, Riccardo
Best, Riccardo
@r_gigante Thank you for your help. I used the maxon::String and it works fine.
