SOLVED c4d threading runs only on one core and is slower than single threaded
put this code in a python generator and place any polygon object under it. run it single threaded , then increase the maxThreads.
it is significant slower when maxThreads > 1.
import math
import time
RootNull = c4d.BaseObject(c4d.Onull)
def currStateToObject(source):
	return c4d.utils.SendModelingCommand(
		 command = c4d.MCOMMAND_CURRENTSTATETOOBJECT,
		 list = [source],
		 mode=c4d.MODELINGCOMMANDMODE_ALL,
		 bc=c4d.BaseContainer(),
		 doc = doc)[0]
def connectDelete(source):
		 command = c4d.MCOMMAND_JOIN,
		 list = [source],
		 bc=c4d.BaseContainer())[0]
class ThreadedCut(c4d.threading.C4DThread):
	def TestBreak(self):
		return None
	def __init__(self, sList):
		print "thread init"
		self.sList = sList
	def Main(self):
		print "thread start"
		for s in self.sList:
			self.CutObject(s)
		print "thread finish"
	def CutObject(self,s):
		global objReference
		# create a copy
		obj = objReference.GetClone()
		allPoints = obj.GetAllPoints()
		bbox = obj.GetRad()
		p1 = c4d.Vector(bbox.x*10,s,bbox.z*10)
		v1 = c4d.Vector(bbox.x*10,0,bbox.z*-10)
		p2 = c4d.Vector(bbox.x*-10,0,bbox.z*10)
		v2 = c4d.Vector(bbox.x*-10,0,bbox.z*-10)
		data = c4d.BaseContainer()
		data.SetVector(c4d.MDATA_KNIFE_P1, p1)
		data.SetVector(c4d.MDATA_KNIFE_P2, p2)
		data.SetVector(c4d.MDATA_KNIFE_V1, v1)
		data.SetVector(c4d.MDATA_KNIFE_V2, v2)
		c4d.utils.SendModelingCommand(c4d.MCOMMAND_KNIFE, [obj], bc=data, doc=doc)
		newPoints = obj.GetAllPoints()
		pointSelection = obj.GetPointS()
		for i in range(len(allPoints),len(newPoints)):
			pointSelection.Select(i)
		bc = c4d.BaseContainer()
		bc.SetData(c4d.MDATA_CONVERTSELECTION_LEFT, 0)
		bc.SetData(c4d.MDATA_CONVERTSELECTION_RIGHT, 1)
		bc.SetData(c4d.MDATA_CONVERTSELECTION_TOLERANT, False)
		c4d.utils.SendModelingCommand(c4d.MCOMMAND_CONVERTSELECTION, [obj], bc=bc, doc=doc)
		c4d.utils.SendModelingCommand(c4d.MCOMMAND_EDGE_TO_SPLINE, [obj])
		if obj.GetDown():
			return obj.GetDown().InsertUnder(RootNull)
		return None
def chunkIt(seq, num):
	https://stackoverflow.com/questions/2130016/splitting-a-list-into-n-parts-of-approximately-equal-length/37414115
	avg = len(seq) / float(num)
	out = []
	last = 0.0
	while last < len(seq):
		out.append(seq[int(last):int(last + avg)])
		last += avg
	return out
objReference = None
	global objReference
	runningThreads = 0
	starttime = time.time()
	obj = currStateToObject(op.GetDown())
	objReference = obj
	maxThreads = 1
	minHeight = -200
	maxHeight = 200
	offset = 0.5
	maxSlices = 10000
	sliceList= []
	for i in range(0,maxSlices):
		s =  minHeight + i*offset
		if (s <= maxHeight and s < obj.GetRad().y*2):
			sliceList.append(s)
			break
	chunks = chunkIt(sliceList,maxThreads)
	tList = []
	for c in chunks:
		print len(c),len(sliceList)
		t = ThreadedCut(c)
		tList.append(t)
	print "threadlist rdy"
	for t in tList:
		t.Start()
	for t in tList:
		t.Wait(True)
	spline = connectDelete(RootNull)
	spline[c4d.SPLINEOBJECT_TYPE] = 3
	spline[c4d.SPLINEOBJECT_CLOSED] = True
	end = time.time()
	print end-starttime
	return spline
Hi @pyr,
In Python, there is a GIL which do not allow Python by design to execute something in parallel.
In Cinema 4D all our functions (so everything which is in the c4d python module) is "GIL safe" in order to avoid any issue with Python memory.
So in Cinema 4D thread are designed for doing GUI, or background stuff.
Moreover, keep in mind creating a Thread have a cost in term of time (to create, execute, delete them).
Finally, I would like to point you to multiprocessing vs multi-threading.
Note that since it's more an algorithm problem than an issue related to our API, we can only provide you hints.
btw, I also turned your topic as a question. See Q&A New Functionality.
Hi @pyr,
