Hello friends, I'm trying to work with the Quaternion-Object. My cam-Object should align to the direction vector and pointed in this case in X-Direction. But if print the q.v value I get a zero vector and the rotation is not applied Does I misunderstood the Quaternion-Syntax? I can't find nothing about that. – Thanks
import c4d cam = op.GetObject() def main(): direction = c4d.Vector(10,0,0).GetNormalized() angle = 0 q = c4d.Quaternion() q.SetAxis(direction, angle) b = q.GetMatrix() b.off = cam.GetAbsPos() cam.SetMg(b) print q.v
please, do not delete discussions threads. The contained information might be valuable for future readers.
Cheers, Andreas
Hi Tudor,
actually your code is properly behaving, since the angle is set to 0. If, by chance, you set it to PI/2 you will immediately see that the camera promptly rotates and point up to the sky.
Hope the screenshot clarifies the situation
Best, Riccardo
I thought I can use this direction vector as Quaternion-Axis. The cam should point than to the target. But but it seems i need a different approach.
import c4d, math cam = op.GetObject() target = op[c4d.ID_USERDATA,1] def main(): tarPos = target.GetAbsPos() camPos = cam.GetAbsPos() direction = (tarPos - camPos).GetNormalized() angle = math.pi/2 #? q = c4d.Quaternion() q.SetAxis(direction, angle) b = q.GetMatrix() b.off = cam.GetAbsPos() cam.SetMg(b)
Hi Tudor, that's indeed not the way to proceed.
Quaternion is just a tool to conveniently represent a rotation in the space. That said the approach you need to follow is just to rotate the camera until it points where your target is.
Cheers, Riccardo
