Drag-n-drop
I am trying out some things related to drag and drop (in a GeUserArea for testing purposes), using the asynctest.cpp sample SDK code.
if (type == DRAGTYPE_ATOMARRAY && ((AtomArray*)object)->GetCount() == 1 && ((AtomArray*)object)->GetIndex(0)) { bl = (C4DAtomGoal*)((AtomArray*)object)->GetIndex(0); if (bl) { if (bl->IsInstanceOf(Tbaselist2d)) string = prefix + str + " " + ((BaseList2D*)bl)->GetName() + " (" + String::IntToString(bl->GetType()) + ")";
Say, I select the Live Selection tool and drag-n-drop its icon from the Attribute Manager into the userarea, I (obviously) get "Live Selection" returned from
GetName()
, but also get value 9 returned fromGetType()
. When I do the same with the move tool i.e. I still get a 9 returned from the type. I have tried to find my way through the documentation, but wasn't able to locate anything related to a "type 9". I know of type Obase, Tbase, Mbase, even Tbaselist2d ... but haven't got a clue what type 9 represents.
When I perform aGetClassification()
I get value 0 returned, which isn't really helpful.
So, what is this mysterious "Number nine" ?
it looks like the "object" that is dragged is the BasePlugin representing the tool plugin.
GetType()
returns the plugin type which is PLUGINTYPE::TOOL (9).You should be able to get the actual tool ID from the
BasePlugin
object:const PLUGINTYPE type = (PLUGINTYPE)baselistObject->GetType(); if (type == PLUGINTYPE::TOOL) { BasePlugin* const plug = (BasePlugin*)(baselistObject); const int toolID = plug->GetID(); ApplicationOutput("Tool ID: " + String::IntToString(toolID)); }
best wishes,
Sebastian
@s_bach
Yes the BasePlugin I already obtained and got its ID, as well as its name. Was just wondering what the 9 represented, in order to use the appropriate defined keyword instead of the value. Thanks for the "PLUGINTYPE::TOOL"
