Hi all,
I'm trying to export a file to fbx format, I'm using R20. On the graphic user interface there's the option to export as fbx format, while, on the python documentation there's not. Here's the reference:
https://developers.maxon.net/docs/Cinema4DPythonSDK/html/modules/c4d.documents/index.html?highlight=savedocument#c4d.documents.SaveDocument
What am I missing?
Hi Rage,
Unfortunately several importers and exporters do not have a constant for their ID. This is the case for FBX. The ID for the FBX exporter is 1026370.
To find the ID of a specific exporter you can use the following code:
import c4d saverPlugs = c4d.plugins.FilterPluginList(c4d.PLUGINTYPE_SCENESAVER, True) for plug in saverPlugs: print('{} : {}'.format(plug.GetName(), plug.GetID()))
I turned the topic into a Q&A. Please remind to use this feature of the forum.
