There is a code in the documentation file that allocates a new user data Here is the code
import c4d def AddLongDataType(obj): if obj is None: return bc = c4d.GetCustomDataTypeDefault(c4d.DTYPE_LONG) # Create default container bc[c4d.DESC_NAME] = "Test" # Rename the entry element = obj.AddUserData(bc) # Add userdata container obj[element] = 30 # Assign a value c4d.EventAdd() # Update
I select and object and execute the code. However, nothing happens. Is there a way around this?
Thank you.
Edit a_block: Fixed code tags.
Hi @bentraje,
Here is the code that can do:
import c4d def AddLongDataType(obj): if obj is None: return bc = c4d.GetCustomDataTypeDefault(c4d.DTYPE_LONG) # Create default container bc[c4d.DESC_NAME] = "Test" # Rename the entry element = obj.AddUserData(bc) # Add userdata container obj[element] = 30 # Assign a value c4d.EventAdd() # Update def main(): obj = doc.GetActiveObject() # Here you get selected/active object from scene AddLongDataType(obj) # Call the AddLongDataType function to add user data to selected object if __name__=='__main__': # The "actual" place that code start to execute main() # Call "main" function, start the processing
Hi, I have fixed the code tags in the first post, see Markdown help. Please also consider using tags, see Read Before Posting. And no worries Cheers, Andreas
@eziopan Thanks mate. It works as expected.
@a_block Thanks. Will double check next time.
