Hi ello,
no, you don't need to worry, the compiler won't check the remaining lines. It is a warning, we use internally to make people write better code. Usually smaller functions are easier to maintain and thinking about how to properly split and slice your code leads to better better results. By the way, compilers nowadays do quite a good job on inlining functions, so one does not need to be afraid of performance issues. But in the end this is probably also a matter of personal taste and so you can configure this in your projectdefinition.txt
. See the Stylecheck options in our Project Tool documentation, there you have the option to set the maximum line count for functions (stylecheck.max-linecount=number
Please consider the use of tags and of our Q&A system.
Andreas
