PluginTag::GetPluginID() method
    On 16/03/2003 at 11:17, xxxxxxxx wrote:
    Cinema 4D Version:   8.1
    Platform:   Windows  ;
    Hi all;
    I am trying to convert some (rather simple) plugins from version 7.3 to 8.1. Now, I am sorely missing a method:
    I get an object's tag list by
    GetFirstTag()
    Then I determine the type of the tag by
    GetType()==Tplugin
    Finally I want to check the plugin's ID. There used to be a method
    GetPluginID()
    , but it is gone (sez da compiler), with afaics no other method in the class hierarchy doing quite what I want (besides, the class PluginTag is a pretty good place to look for such a method).
    How do I get the plugin's registered ID? Not Tplugin, but the unique plugin-specific ID I (or someone else) got from Maxon. Where did that method move?
    Thanks,
    -- Cairyn --
    On 18/03/2003 at 00:18, xxxxxxxx wrote:
    okay, after some debugging I found the solution.
    Apparently, the tag's method
    GetType()
    does no longer return the constant
    Tplugin
    for plugin tags, as it did in the V7.3 API, but the assigned ID instead.
    *sigh* I really wish someone would document changes in behaviour like that...
    -- Cairyn --
    On 18/03/2003 at 09:37, xxxxxxxx wrote:
    Thanks. Though the need for explicit R7 conversion docs should ideally become less over time, I'll at least make sure that Atom::GetType() gets the right description.
