Description... missing member "ID"
while updating to r20 i get a lot of errors according to DescriptionCommad / DescriptionGetBitmap, ID is no member
case MSG_DESCRIPTION_COMMAND: switch(static_cast<DescriptionCommand*>(t_data)->id[0].id)
case MSG_DESCRIPTION_GETBITMAP: DescriptionGetBitmap *dgb = static_cast<DescriptionGetBitmap*>(t_data); AutoAlloc<BaseBitmap> bm; switch(dgb->id[0].id)
edit: maybe i found something . _descId[0].id doesn't throw an error. however i still cannot test way more errors and warnings to go ;)
In R20, it changed to
id[0]._descId
@rsodre so it is wrong way? my code seems to compile now
in Cinema 4D R20 the
id
member was removed from several structures likeDescriptionCommand
orDescriptionPopup
. These structures now share a common base class: DescriptionBaseMessage. See API Change List in R20.DescriptionBaseMessage
has the member_descId
which can be used instead.Is your issue solved with that information?
best wishes,
Sebastian
@s_bach thank you. i still am on my road... at least it solves the compiler error. i get quite some crashes after updating. guess this will take some time
