SOLVED Is C4D_PLUGINS_DIR env var still working (R20.0.28)?
Hello all,
good job on the new forum, looks really nice.
I was going through the update process from R19 to R20, and I wanted to check if I could get several paths for C4D_PLUGINS_DIR working, since I haven't been able to achive this (see: ).
But it seems to not be working with even a single path? I'm trying to get Arnold loaded in C4D, here are the environment variables:
C4D_BROWSERLIBS=C:\env_manager\packages\arnold_for_cinema4d\2.4.1.2/C4DtoA-2.4.1.2/library
C4D_PLUGINS_DIR=C:\env_manager\packages\arnold_for_cinema4d\2.4.1.2/C4DtoA-2.4.1.2/plugins/
And the folder structure in that path is as follows (normal C4DtoA plugin struct):
C:\ENV_MANAGER\PACKAGES\ARNOLD_FOR_CINEMA4D\2.4.1.2\C4DTOA-2.4.1.2
├───library
│   ├───browser
│   ├───materialpreview
│   └───scripts
└───plugins
    └───C4DtoA
        ├───api
        │   ├───bin
        │   ├───include
        │   │   ├───customgui
        │   │   ├───meta
        │   │   │   └───param
        │   │   ├───module
        │   │   ├───node
        │   │   ├───render
        │   │   ├───translator
        │   │   │   ├───driver
        │   │   │   ├───light
        │   │   │   ├───material
        │   │   │   ├───object
        │   │   │   ├───shader
        │   │   │   └───tag
        │   │   └───util
        │   └───lib
        ├───arnold
        │   ├───bin
        │   ├───materialx
        │   │   └───arnold
        │   ├───plugins
        │   └───python
        │       └───arnold
        ├───procedurals
        ├───res
        │   ├───description
        │   ├───dialogs
        │   ├───icons
        │   └───strings_en-US
        │       ├───description
        │       └───dialogs
        └───shaders
Yet when I launch Cinema4D, the plugin won't load, if I install this same package inside the Cinema4D folder it does work.
So any ideas?
Thanks,
Oscar.
in Cinema 4D R20 the environment variable C4D_PLUGINS_DIR has been removed.
It has been replaced with g_additionalModulePath. You can use this command also as a command line argument.
See Environment Variables.
Please notice that you can mark your post also as a question. See Q&A New Functionality.
best wishes,
Sebastian
