I'm trying to create a GUI tool that lets me change the display color at will. Since we are talking about colors, I would like to the "buttons" to be colors rather than just a plain text button "Change to Green". You cans see an example attached in this post.
https://www.dropbox.com/s/j7k385dlx0obnb2/c4d070_UI_colorizer.JPG?dl=0
I tried looking up in the GUI documentation but nothing seems to fit my description.
Is there a way around this? Thank you for looking at my problem.
may I ask you to please add tags to your post (see Read Before Posting)? For example I'm not sure, if you are looking for a C++ or Python solution.
In general the BitmapButtonCustomGui (C++, Python) should do the trick for you.
You can see the usage in our C++ examples: In a parameter description: objectdata_descriptions.cpp In a GeDialog: gedialog_gadgets.cpp
Cheers, Andreas
Apologies for the confusion. I'm using a python. Just starting out
Thanks for the reference, but I'm not quite sure how to use it.
Here is what I have so far
import c4d from c4d import gui Green = 100 class Colorizer(gui.GeDialog): def CreateLayout(self): self.SetTitle('Colorizer') self.BitmapButtonCustomGui(BITMAPBUTTON_BACKCOLOR = c4d.Vector(0,1,0)) #self.AddButton (Green , c4d.BFH_CENTER ,name='Green') def main(): dialog = Colorizer() dialog.Open(c4d.DLG_TYPE_MODAL_RESIZEABLE, defaultw=300,defaulth=100) if __name__=='__main__': main()
Currently, it returns an error of AttributeError: 'Colorizer' object has no attribute 'BitmapButtonCustomGui'.
thanks for the additional information and setting the tags.
The BitmapButton needs to be added to the dialog via AddCustomGui(). For example like so:
# Prepare a red bitmap for the button. w = 50 h = 50 bmpRed = c4d.bitmaps.BaseBitmap() bmpRed.Init(w, h) for y in xrange(w): for x in xrange(h): bmpRed.SetPixel(x, y, 255, 0, 0) # BitmapButton configuration bcBitmapButton = c4d.BaseContainer() bcBitmapButton[c4d.BITMAPBUTTON_BUTTON] = True # Add a BitmapButton to the dialog. # _bitmapButton is a member variable of the dialog class buttonId = 2000 _bitmapButton = self.AddCustomGui(buttonId, c4d.CUSTOMGUI_BITMAPBUTTON, "", c4d.BFH_CENTER|c4d.BFV_CENTER, w, h, bcBitmapButton) if _bitmapButton is None: print "Handle this error!" # Assign the image to the button. # Note: Let it create an internal copy as the created bitmap will be free'd, when scope is left. _bitmapButton.SetImage(bmpRed, True)
Thank you for taking the time to make the code and make comments. Appreciate it alot. The GUI creation is resolved but can I ask how do I connect the button (Red/Green bitmap) to the command.
I tried modifying and confirming the button ID and the command ID but does not seem to work. You can see the work here (and sorry again for the trouble)
import c4d from c4d import gui mainLayout = 1000 bnRed = 1001 bnGreen = 1002 bnBlue = 1003 class Colorizer(gui.GeDialog): def CreateLayout(self): self.SetTitle('Colorizer') # Prepare a red bitmap for the button. self.GroupBegin (mainLayout, c4d.BFV_CENTER, cols=2,rows=3) w = 25 h = 25 bmpRed = c4d.bitmaps.BaseBitmap() bmpRed.Init(w, h) for y in xrange(w): for x in xrange(h): bmpRed.SetPixel(x, y, 255, 0, 0) # BitmapButton configuration bcBitmapButton = c4d.BaseContainer() bcBitmapButton[c4d.BITMAPBUTTON_BUTTON] = True # Add a BitmapButton to the dialog. # _bitmapButton is a member variable of the dialog class #buttonId = 2000 _bitmapButton = self.AddCustomGui(bnRed, c4d.CUSTOMGUI_BITMAPBUTTON, "", c4d.BFH_CENTER|c4d.BFV_CENTER, w, h, bcBitmapButton) if _bitmapButton is None: print "Handle this error!" # Assign the image to the button. # Note: Let it create an internal copy as the created bitmap will be free'd, when scope is left. _bitmapButton.SetImage(bmpRed, True) bmpGreen = c4d.bitmaps.BaseBitmap() bmpGreen.Init(w, h) for y in xrange(w): for x in xrange(h): bmpGreen.SetPixel(x, y, 0, 255, 0) bcBitmapButton = c4d.BaseContainer() bcBitmapButton[c4d.BITMAPBUTTON_BUTTON] = True _bitmapButton = self.AddCustomGui(bnGreen, c4d.CUSTOMGUI_BITMAPBUTTON, "", c4d.BFH_CENTER|c4d.BFV_CENTER, w, h, bcBitmapButton) if _bitmapButton is None: print "Handle this error!" _bitmapButton.SetImage(bmpGreen, True) self.GroupEnd() return True def colorRed (self,id,msg): if id == bnRed: op[c4d.ID_BASEOBJECT_USECOLOR] = 2 op[c4d.ID_BASEOBJECT_COLOR] = c4d.Vector (1,0,0) c4d.EventAdd() self.Close() return True def colorGreen (self,id,msg): if id == bnGreen: op[c4d.ID_BASEOBJECT_USECOLOR] = 2 op[c4d.ID_BASEOBJECT_COLOR] = c4d.Vector (1,0,0) c4d.EventAdd() self.Close() return True def main(): dialog = Colorizer() dialog.Open(c4d.DLG_TYPE_MODAL_RESIZEABLE, defaultw=300,defaulth=100) if __name__=='__main__': main()
you have to react to the button in your GeDialog implementation, namely in the Command() function. See for example these lines in the Py-TextureBaker example.
So picking up my example snippet from above, the Command function could look like so:
def Command(self, id, msg): if id==2000: # corresponds to the button ID used in the code snippet in the first answer in this thread print "My Bitmap Button" return True
Hi Andreas,
Thank you for the response and apologies for dragging this further.
The code you have given works only for "print" command. But when I added my block of commands, it doesn't work on anything.
The code in question is (please see comments)
def Command (self,id,msg): if id == 2000: print "My Bitmap Button" # this code works op[c4d.ID_BASEOBJECT_USECOLOR] = 2 #However, the following two do not. op[c4d.ID_BASEOBJECT_COLOR] = c4d.Vector (1,0,0) #They work on a standalone script but on this button return True
Sorry for the trouble I'm just a newbie on scripting in general. Is there other prerequisite on executing the code?
no worries, we'll get you there.
One recommendation: When doing Python development, have the Cinema 4D Console window open (Menu Script -> Console...). There you will be presented with errors.
I think, your problem will be, that you try to access op, probably intending to change parameters of the active object. In Script Manager doc and op are global variables predefined for convenience. In a plugin, you have to get these yourself using GetActiveDocument() and GetActiveObject().
op
doc
Bye, Andreas
@a_block
Case solved! Thanks again for your patience.
