Hi, is there a way to modify the shape of a Spline in the Spline Gui? For example I want to edit the Curve in the Splinedeformer Shape Parameter. The Log only spits out c4d.SPLINEDEFORMEROBJECT_SPLINECONTROL How can I modify the cooridates of the spline points?
the parameter c4d.SPLINEDEFORMEROBJECT_SPLINECONTROL contains a c4d.SplineData object. You can edit this object to edit the spline.
Please notice that the Spline Deformer adapts the spline range based on the "Radius" parameter.
With that in mind you can easily access and edit the points defining that spline:
# get spline data splineData = op[c4d.SPLINEDEFORMEROBJECT_SPLINECONTROL] # print information on the data print(splineData) # radius is max. value radius = op[c4d.SPLINEDEFORMEROBJECT_RADIUS] # delete all points splineData.DeleteAllPoints() splineData.SetRange(0.0, radius, 0.1, 0.0, 1.0, 0.1) # insert knots splineData.InsertKnot(0.0, 0.0) splineData.InsertKnot(radius, 1.0) # modify knots splineData.SetKnot(0,c4d.Vector(0.0,0.0,0), 0, False, c4d.Vector(0,0,0), c4d.Vector(1,1,0),c4d.CustomSplineKnotInterpolationBezier) splineData.SetKnot(1,c4d.Vector(radius,1.0,0), 0, False, c4d.Vector(-1,-1,0), c4d.Vector(0,0,0),c4d.CustomSplineKnotInterpolationBezier) # store back to deformer object op.SetParameter(c4d.SPLINEDEFORMEROBJECT_SPLINECONTROL, splineData, c4d.DESCFLAGS_SET_0) c4d.EventAdd()
best wishes, Sebastian
Hello @HolgerBiebrach ,
I'm wondering if your question has been answered. If so, please mark this thread as solved.
