Hello guys! Working on updating plugins for C4D R20. Have an error: "OverflowError: unsigned byte integer is greater than maximum" when trying to update Tool plugin interface EditNumberArrows field with numbers greater then 255 (there is no error if number less or equal then 255) using commang GeDialog.SetInt32(0001,int(var),min=0, max=c4d.MAXLONGl, step=1, tristate=False, min2=0, max2=c4d.MAXLONGl) or GeDialog.SetLong(0001,int(var),min=0, max=c4d.MAXLONGl, step=1, tristate=False, min2=0, max2=c4d.MAXLONGl)
On C4D R19 it works fine...
See here: https://developers.maxon.net/docs/Cinema4DCPPSDK/html/page_list_of_name_changes_in_r15_api.html There has probably changed more than the names only.
@mp5gosu thanks for your reply, but this error appears also with new names like SetInt32
Oh, didn't notice you're working with python. I'll take a look into it later.
Hey there,
I tried to replicate you issue but wasn't able to. Here's some code I used and everything works as expected:
import c4d from c4d import gui var = float(2520.023) class myDlg(gui.GeDialog): def Execute(doc): print "Hi" return true def CreateLayout(self): self.AddEditNumberArrows(1001, c4d.BFH_SCALEFIT | c4d.BFH_SCALEFIT, initw=70, inith=40 ) return True def InitValues(self): self.SetInt32(1001,int(var),min=0, max=c4d.MAXLONGl, step=1, tristate=False, min2=0, max2=c4d.MAXLONGl) return True def main(): dlg = myDlg() dlg.Open(dlgtype=c4d.DLG_TYPE_MODAL, pluginid=1050902, defaultw=400, defaulth=32) if __name__=='__main__': main()
I have some questions about your code:
var
(int)var
Cheers, Robert
The OverFlow error is thrown when SetInt32() is called from a SubDialog (used for Tool plugins settings). I'm afraid a regression was introduced in R20. It will be fixed in the next update.
SetInt32()
SubDialog
The workaround in R20 is to perform in Python what GeDialog::SetInt32() does in the C++ API (see cinema.framework/source/c4d_gui.cpp).
import sys def StringToID(str): return int('0x'+hex(ord(str[0]))[2:4]+hex(ord(str[1]))[2:4]+hex(ord(str[2]))[2:4]+hex(ord(str[3]))[2:4], 16) CM_TYPE_INT = StringToID('vint') CM_VALUE_VAL = StringToID('valu') CM_VALUE_FORMAT = StringToID('frmt') CM_VALUE_MIN = StringToID('mini') CM_VALUE_MAX = StringToID('maxi') CM_VALUE_MIN2 = StringToID('min2') CM_VALUE_MAX2 = StringToID('max2') CM_VALUE_STEP = StringToID('step') CM_VALUE_TRISTATE = StringToID('tris') def SetInt32(dlg, id, value, min=-sys.maxint-1, max=sys.maxint, step=1, tristate=0, min2=-sys.maxint-1, max2=sys.maxint): msg = c4d.BaseContainer(CM_TYPE_INT) msg[CM_VALUE_VAL] = value msg[CM_VALUE_FORMAT] = c4d.FORMAT_INT msg[CM_VALUE_MIN] = min msg[CM_VALUE_MAX] = max msg[CM_VALUE_STEP] = step msg[CM_VALUE_TRISTATE] = tristate if min2 != -sys.maxint-1 or max2 != sys.maxint: msg[CM_VALUE_MIN2] = min2 msg[CM_VALUE_MAX2] = max2 return dlg.SendMessage(id, msg) != 0
Call this SetInt32() from the subdialog to initialize any integer value. Note c4d.MINLONGl and c4d.MAXLONGl are no longer used internally. The documentation has to be updated.
c4d.MINLONGl
c4d.MAXLONGl
Hi @mikeudin,
I'm wondering if your question has been answered. If so, please mark this thread as solved.
Cheers, Yannick
