Force InExclusionData update after remove object outside of In-/Exclusion User Data
I have a very simple scene:- A
Null Object
with anIn-/Exclusion User Data
- A
Python Tag
on theNull Object
- some script in the
Python Tag
import c4d def main(): obj = op.GetObject() objList = obj[c4d.ID_USERDATA,1] # point to the In-/Exclusion User Data print(objList.GetObjectCount())
If I add scene objects into
, or remove object withinIn-/Exclusion User Data
,Python Tag
will print correct object count.But if I remove an object from the
Object Manager
which had been added into theIn-/Exclusion User Data
before, I can see object has been removed inIn-/Exclusion User Data
, butPython Tag
report wrong object count (as if the object has not been removed).And only if I make some change within the
directly, that thePython Tag
report correct count number again.I wonder if there is something I'm missing from the script for forcing
InExclusionData
update, or it's a bug in the "updating system"?Thanks!
- A
The
InExcludeData
object count does not always reflect the accurate number of valid objects depending on the scenarios.
Additionally to callingGetObjectCount()
the returned value fromObjectFromIndex()
should be checked if it's not None.
Hi, y_puech!
Thank you for replying!
I usei = 0 while True: obj = InExData.ObjectFromIndex(doc,i) if obj == None: break i += 1
to get right result.
Just a quick note on your code. A pythonic solution could be:
count = inExData.GetObjectCount() for i in xrange(count): obj = inExData.ObjectFromIndex(doc, i) if obj is None: continue
Why are you breaking out from the loop with the first invalid object in the InExcludeData?
Oh! Sorry! I know what you mean in the previous post now. I'm doing the wrong way. Your solution is correct!
By the way, I wonder if there is a situation where the actual object counts are greater than GetObjectCount() returned?
This should never happen.
Thanks for marking the topic as solved. Note that you can mark a specific post as the correct answer or solution. See step 5 in Q&A New Functionality.
Hi, @y_puech I may find a bug of the forum about "mark a post correct answer", discussion post here: Cannot mark post as answer
Once this bug solved, I will re-edit this topic and posts correctly.
