Hello. There seems to be a change from R19 to R20, in R19 I was able to have a nested folder within the Plugin folder and it would create a sub-folder along side it and that hierarchy would be reflected inside of Cinema's Plugins menu.
For example:
Plugins Test Plugin Folder 1 Plugin 1 Test Plugin Folder 2 Plugin 2
So this is how it would appear as a folder structure and how it would appear in Cinema in R19.
In R20 though having a folder structure like that outputs as this in the plugin menu.
In no longer creates the sub-folder like it used to. Is it possible to get that functionality back with just using folders?
Daniel
Hello Daniel,
thanks for reporting this. There are currently a few issues regarding the Plugins menu pending. These are being investigated.
Cheers, Andreas
