Viseme RIG test
in order to faster the mouth animation process of a character,
i try to create a viseme rig.
I have put on an object a pose morph tag with 6 sliders for 6 visemes.
I created a dynamic text in user data, to edit viseme orders .
I created an Xpresso tag, with python node, to control visemes sliders.
It works, but in a boolean way !
I want to improve this Xpresso and python Rig to control sliders
in a linear way (from 0% to 100%, or 100% to 0%) !
With duration for the moving sliders between viseme orders
With conditions for the position of the sliders (e.g.: if slider 1 at position 0, go to 100, if slider 2 at position 100, go to 0 ....).
How can i do it ?
I'm a python rookie !
Thank's
Hi Gal, thanks for writing us.
With regard to the issue reported, it looks to me like some sorting of unwanted data-clamping effect due to type casting. To be more helpful please provide your code snippet ( or a complete test asset) in order to dig further.
Best, Riccardo
@r_gigante said in Viseme RIG test:
Hi Ricardo,
Thank you for your answer.
I've a little bit improved my xpresso nodes, simple but efficient !
The viseme are controlled in a boolean way = step key frame.
With controlling the global intensity of the pose morph tag,
i can have more interpolation of the lips movement between the viseme step keys frames.
Mouth rig test_animatic
How to improved python code in order to have viseme linear key frames ?
Thanks
Best regards
Gal
This is my simple python code :
    global Output1, Output2, Output3, Output4,  Output5,  Output6,  Output7,  Output8,  Output9,  Output10,  Output11
    if Input1 == "":
        Output1 = 0
        Output2 = 0
        Output3 = 0
        Output4 = 0
        Output5 = 0
        Output6 = 0
        Output7 = 0
        Output8 = 0
        Output9 = 0
        Output10 = 0
        Output11 = 0
    if Input1 == "E":
        Output1 = 1
        Output2 = 0
        Output3 = 0
        Output4 = 0
        Output5 = 0
        Output6 = 0
        Output7 = 0
        Output8 = 0
        Output9 = 0
        Output10 = 0
        Output11 = 0
    if Input1 == "A":
        Output1 = 0.8
        Output2 = 0
        Output3 = 0
        Output4 = 0.8
        Output5 = 0
        Output6 = 0
        Output7 = 0
        Output8 = 0
        Output9 = 0
        Output10 = 0.5
        Output11 = 0.5
    if Input1 == "I":
        Output1 = 0
        Output2 = 0
        Output3 = 0
        Output4 = 1
        Output5 = 0
        Output6 = 1
        Output7 = 1
        Output8 = 0
        Output9 = 0
        Output10 = 0.5
        Output11 = 0.5
    if Input1 == "U":
        Output1 = 0.8
        Output2 = 0
        Output3 = 0
        Output4 = 0
        Output5 = 0
        Output6 = 0
        Output7 = 0
        Output8 = 1
        Output9 = 1
        Output10 = 0
        Output11 = 0
    if Input1 == "R":
        Output1 = 0.5
        Output2 = 0
        Output3 = 0
        Output4 = 1
        Output5 = 0
        Output6 = -0.5
        Output7 = -0.5
        Output8 = 1
        Output9 = 1
        Output10 = 0.5
        Output11 = 0.5
    if Input1 == "O":
        Output1 = 0.9
        Output2 = 0
        Output3 = 0
        Output4 = 0
        Output5 = 0
        Output6 = 0
        Output7 = 0
        Output8 = 0.4
        Output9 = 0.4
        Output10 = -0.3
        Output11 = -0.3
    if Input1 == "CH":
        Output1 = 0.2
        Output2 = 0
        Output3 = 0
        Output4 = 0.35
        Output5 = 0
        Output6 = 0.5
        Output7 = 0.5
        Output8 = 0
        Output9 = 0
        Output10 = 0.6
        Output11 = 0.6
    if Input1 == "S":
        Output1 = 0.1
        Output2 = 0
        Output3 = 0
        Output4 = 0.41
        Output5 = 0.2
        Output6 = 1
        Output7 = 1
        Output8 = 1
        Output9 = 1
        Output10 = 1
        Output11 = 1
    if Input1 == "M":
        Output1 = 0
        Output2 = 0
        Output3 = 0
        Output4 = 0.1
        Output5 = 0.3
        Output6 = 0.6
        Output7 = 0.6
        Output8 = 0.85
        Output9 = 0.85
        Output10 = 0.4
        Output11 = 0.4
    if Input1 == "D":
        Output1 = 0.05
        Output2 = 0
        Output3 = 0
        Output4 = 0.3
        Output5 = 0.2
        Output6 = 0.8
        Output7 = 0.8
        Output8 = 0.85
        Output9 = 0.85
        Output10 = 0.2
        Output11 = 0.2
    if Input1 == "F":
        Output1 = 0.05
        Output2 = 0
        Output3 = 0
        Output4 = 0
        Output5 = 0.2
        Output6 = 0.8
        Output7 = 0.8
        Output8 = 0.5
        Output9 = 0.5
        Output10 = 0
        Output11 = 0
    if Input1 == "L":
        Output1 = 0.6
        Output2 = 1
        Output3 = 0
        Output4 = 0.2
        Output5 = 0
        Output6 = 0.8
        Output7 = 0.8
        Output8 = 0.5
        Output9 = 0.5
        Output10 = 0
        Output11 = 0
Hi Gal, thanks for following-up.
With regard to your setup, without changing too much things, you could simply consider to add an additional float parameter to your VISEME data - in order to have three input params "neutral", "VISEME" and a "weight" - and use its value defined by a curve in your python script (below to keep your naming scheme is called Input2) in order to change the weight of your VISEME rig.
    # Input2 is the float parameter defined to weight the viseme
    Output1 = 0
    Output2 = 0
    Output3 = 0
    Output4 = 0
    Output5 = 0
    Output6 = 0
    Output7 = 0
    Output8 = 0
    Output9 = 0
    Output10 = 0
    Output11 = 0
    if Input1 == "E":
        Output1 = 1.0 * Input2
    elif Input1 == "A":
        Output1 = 0.8 * Input2
        Output4 = 0.8 * Input2
        Output10 = 0.5 * Input2
        Output11 = 0.5 * Input2
    elif Input1 == "I":
        Output4 = 1.0 * Input2
        Output6 = 1.0 * Input2
        Output7 = 1.0 * Input2
    elif Input1 == "U":
        Output8 = 1.0 * Input2
        Output9 = 1.0 * Input2
    elif Input1 == "R":
        Output1 = 0.5 * Input2
        Output6 = -0.5 * Input2
        Output7 = -0.5 * Input2
    elif Input1 == "O":
        Output1 = 0.9 * Input2
        Output8 = 0.4 * Input2
        Output9 = 0.4 * Input2
        Output10 = -0.3 * Input2
        Output11 = -0.3 * Input2
    elif Input1 == "CH":
        Output1 = 0.2 * Input2
        Output4 = 0.35 * Input2
        Output6 = 0.5 * Input2
        Output7 = 0.5 * Input2
        Output10 = 0.6 * Input2
        Output11 = 0.6 * Input2
    elif Input1 == "S":
        Output1 = 0.1 * Input2
        Output4 = 0.41 * Input2
        Output5 = 0.2 * Input2
        Output10 = 1.0 * Input2
        Output11 = 1.0 * Input2
    elif Input1 == "M":
        Output4 = 0.1 * Input2
        Output5 = 0.3 * Input2
        Output6 = 0.6 * Input2
        Output7 = 0.6 * Input2
        Output8 = 0.85 * Input2
        Output9 = 0.85 * Input2
        Output10 = 0.4 * Input2
        Output11 = 0.4 * Input2
    elif Input1 == "D":
        Output1 = 0.05 * Input2
        Output4 = 0.3 * Input2
        Output6 = 0.8 * Input2
        Output7 = 0.8 * Input2
        Output10 = 0.2 * Input2
        Output11 = 0.2 * Input2
    elif Input1 == "F":
        Output8 = 0.5 * Input2
        Output9 = 0.5 * Input2
    elif Input1 == "L":
        Output1 = 0.6 * Input2
        Output2 = 1.0 * Input2
        Output4 = 0.2 * Input2
Hoping it make sense, feel free to get back for any further help.
Cheer, Riccardo
Hello
Thank you Ricardo for the code and this option.
It works for me !
Is there a way to control an interpolation of data (e.g. 0 to 100) on a duration (e.g. 10 frames) with python, with only one order keyframe ?
If you have an advice or a weblink to better learn python for C4D, i'll take it !
Thanks
Gal
Hi! You could go for CTracks via Python. You'd have to get the track for a position parameter, for example, or create one, then get curve, then add keys. Later, you could simply range map it back to your Xpresso rig. it It's definitely doable!
