Hi! sorry for my bad english I found this strange behavior in the Extrude tool:
import c4d from c4d import gui, utils def main(): #Estrusioni settings = c4d.BaseContainer() settings[c4d.MDATA_EXTRUDE_OFFSET] = 20 settings[c4d.MDATA_EXTRUDE_CREATECAPS] = False settings[c4d.MDATA_EXTRUDE_SUBDIVISION] = 0 settings[c4d.MDATA_EXTRUDE_PRESERVEGROUPS]=True utils.SendModelingCommand(command = c4d.ID_MODELING_EXTRUDE_TOOL,list = [op], mode = c4d.MODELINGCOMMANDMODE_POLYGONSELECTION, bc = settings,doc = doc, flags=c4d.MODELINGCOMMANDFLAGS_CREATEUNDO) c4d.EventAdd() if __name__=='__main__': main()
[c4d.MDATA_EXTRUDE_PRESERVEGROUPS]=True is always False
as described in the user help for the Extrude, Preserve Groups works in combination with the Maximum Angle parameter. So you also need to set MDATA_EXTRUDE_ANGLE for it to work.
Cheers, Andreas
Now Work Thanks Andreas
