Issue Changing Modeling Axis
I'm trying to convert a working COFFEE script for changing the modeling axis to Python. Updated tool data is printed to the Console but the Axis parameter is not changing.
import c4d def main(): tool_dat = doc.GetActiveToolData() tool_dat[c4d.MDATA_AXIS_MODE] = c4d.MDATA_AXIS_MODE_FREE c4d.EventAdd() if __name__=='__main__': main()
The script you posted does work with for instance the Live Selection tool but does not work with Move/Scale/Rotate tools.
The following script changes theMDATA_AXIS_MODE
toMDATA_AXIS_MODE_FREE
for any active tool:import c4d from c4d import plugins def SetToolData(doc, toolID, paramID, data): plug = plugins.FindPlugin(toolID, c4d.PLUGINTYPE_TOOL) if plug is None: return plug[paramID] = data def main(): SetToolData(doc, doc.GetAction(), c4d.MDATA_AXIS_MODE, c4d.MDATA_AXIS_MODE_FREE) c4d.EventAdd() if __name__=='__main__': main()
The above script does not use
GetActiveToolData()
. It retrieves the object for the active tool (withFindPlugin()
) and sets the parameter (with operator[]
For some technical reason, several tools need their settings to be changed via parameters and not accessing the tool data container directly.Best regards,
Yannick
GetActiveToolData()
Yannick
Thanks for the solution and explanation Yannick. It's working perfectly now and I can finish converting my scripts.
