When posting questions please make sure to use the correct category.
Please add tags to your posts to help in organizing the forum. Tags can be selected by a drop-down list provided by the tagging button on the bottom/left of the composer. Tags are also filtered depending on the category where the post/topic is supposed to appear: different categories offer different tags.
For example, when posting in "Cinema 4D Development", you can add (but not limited to):
or more generic labels like:
For example, when posting in "General Programming and Plugins", you can add (but not limited to):
This forum uses Markdown. See commonmark.org/help/
Please use Markdown to format code like `SomeFunction()` or a complete code block: ```
SomeFunction()
BaseObject* const cube = BaseObject::Alloc(Ocube); if (cube == nullptr) return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION);
``` This forum also offer a Q&A functionality, please make use of it.
Cheers, MAXON's SDK Team
