PolygonReduction class is not renderable
On 26/08/2018 at 03:30, xxxxxxxx wrote:
I'm using PolygonReduction class in my OBJECT_GENERATOR plugins.
When I'm making the desired object a child of it, it works correctly and but it is not working when I'm rendering it with physical render in the viewport.import c4d class test(c4d.plugins.ObjectData) : def GetVirtualObjects(self, op, hh) : if not op.GetDown() : return None gch = op.GetAndCheckHierarchyClone(hh, op.GetDown(), c4d.HIERARCHYCLONEFLAGS_ASPOLY, False) polyObject = gch["clone"] if not gch["dirty"]: return polyObject data = {} data['_op'] = polyObject data['_doc'] = op.GetDocument() data['_thread'] = None polyReduction = c4d.utils.PolygonReduction() if not polyReduction.PreProcess(data) : return True polyReduction.SetReductionStrengthLevel(0.9) polyObject.Message(c4d.MSG_UPDATE) return polyObject if __name__ == "__main__": result = c4d.plugins.RegisterObjectPlugin(id = 1000001,str = "?",g = test,description = "",info = c4d.OBJECT_GENERATOR|c4d.OBJECT_INPUT,icon = None)
Download Plugin: https://www.dropbox.com/s/97c9xn941ywurg9/Test%20Plugin%200.4.zip?dl=0
On 26/08/2018 at 03:36, xxxxxxxx wrote:
I guess this is a bug so I moved it to bugs section: https://plugincafe.maxon.net/topic/10933/14390_polygonreduction-is-not-renderablephysical
