On 19/07/2018 at 06:12, xxxxxxxx wrote:
Hi.folks! I met a problem that made me depressed. I have a polygon name "A" object that have a skin deformer.A null Object name "CTR" with a python tag to get "A" point (Index :2) position to "CTR" position. A spline object name "sp" that have a python tag to control the "sp" point position,A polygon object name "B" that have a spline warp deformer. Theoretical caculate sequence:skin deformer of "A" (base priority is Generators : -2, )--->python tag of "CTR",get the point (index : 2 ) position to "CTR" (python tag base priority is Generators : -1) ---> python tag of "sp" use "A" position to control "sp" point (python tag base priority is Generators: -1) ---> caculate spline wrap deformer of "B" (b) but delay problem appears with python tag of "CTR" . his code `
s!
(b)
his code
` ` A = op[c4d.ID_USERDATA,1] # Userdata is polygon name "A" AMG = A.GetMg() cache = A.GetDeformCache() CTR = op.GetObject() CTR.SetAbsPos(AMG * cache.GetPoint(2))
when i move joint ,the "CTR" position have delay problem. Thanks for your help! `
On 20/07/2018 at 03:38, xxxxxxxx wrote:
This looks like a priority issue. What's the priority of the Python tag on null object "CTR"? Is it set to Generators?
On 20/07/2018 at 04:13, xxxxxxxx wrote:
yes,skin set Genetators : -2 --> "CTR" Python tag set Genetators : -1 -->"sp"Python tag set Generators : -1 --> spline warp deformer
