On 05/07/2018 at 21:59, xxxxxxxx wrote:
User Information: Cinema 4D Version: R19 Platform: Windows ; Mac OSX ; Language(s) : C++ ; PYTHON ;
--------- Hello,
In continuation to the shortcut-key topic and the sticky-key bug, I was looking for a way to detect a key release. Let's say I have a SceneHook, in its KeyboardInput I can detect a key being pressed. This method is being called when the user presses a key, or when the key is kept pressed down. Is there any way to detect the key being released?
Note, we're in a SceneHook, performing a while loop to check for the release of the key is thus not an option. Moving all the logic into a ToolData is not an option either.
On 09/07/2018 at 02:26, xxxxxxxx wrote:
Hi C4DS, thanks for writing us and sorry for coming back late.
With regard to your question, being looking into ToolData out of discussion as you stated above, a plausible, but non-official, way to be informed about the key release could be represented by the next sub-optimal worrkaround.
The idea is to store the key press state in a member variable of your SceneHookData plugin and at the SceneHookData::Execute() call time compare the stored value with the current one to detect a change in the state.
Could it be worthy to give it a try? Maybe there could be some lag between the key release and the Execute() method execution but maybe it's something you could live with.
Best, Riccardo
On 09/07/2018 at 03:08, xxxxxxxx wrote:
Cannot get the Execute to work in the SceneHook. I mean, Execute isn't performed when I press a key, it only is called when I click the mouse button, which then leads to "Cinema 4D has triggered a breakpoint".
I am capturing the pressed key in KeyboardInput and check in Execute as follows
Bool WOTSceneHook::KeyboardInput(BaseSceneHook* node, BaseDocument* doc, BaseDraw* bd, EditorWindow* win, const BaseContainer& msg) { Int32 key = msg.GetData(BFM_INPUT_CHANNEL).GetInt32(); mKeyPressed = key; GePrint(String::IntToString(mKeyPressed)); return SUPER::KeyboardInput(node, doc, bd, win, msg); } EXECUTIONRESULT WOTSceneHook::Execute(BaseSceneHook *node, BaseDocument *doc, BaseThread *bt, Int32 priority, EXECUTIONFLAGS flags) { if (mKeyPressed) { BaseContainer bc; if (GetInputState(BFM_INPUT_KEYBOARD, mKeyPressed, bc)) { GePrint("mKeyPressed"); } } return EXECUTIONRESULT_OK; }
From the moment I pressed a key (with cursor in the viewport), I always get a "Cinema 4D has triggered a breakpoint" whenever the mouse leaves the viewport.
I must be missing something.
