On 06/03/2003 at 09:51, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.012 Platform: Windows ; Mac ; Mac OSX ; Language(s) : C++ ;
--------- Is there a way to hide/unhide parameters. I know there is a flag for HIDDEN but it seems it cannot be changed. Any ideas?
bt
On 06/03/2003 at 10:50, xxxxxxxx wrote:
Search the Forum!!!
On 06/03/2003 at 12:00, xxxxxxxx wrote:
Quote: Originally posted by 3D Designer on 06 March 2003 > > * * * > > Search the Forum!!! > > > * * *
I have searched both topic and message body under 'parameter visibility', 'HIDDEN'. I do not know what else to seed the search with, suggestions?
On 06/03/2003 at 12:25, xxxxxxxx wrote:
Hi, I had the same problem some time ago, that´s why I know it´s in the forum! U should have used HIDE instead of HIDDEN but here is the answer Mikael Sterner gave me.
Here's a dummy GetDDescription() I added to my MSA object. It HIDEs the POSITIONING_FROM_POS element: Bool MSAObject::GetDDescription(GeListNode *node, Description *description,LONG &flags) { if (!description || !node) return FALSE; if (!description->LoadDescription(node->GetType())) return FALSE; AutoAlloc<AtomArray> ar; if (!ar) return FALSE; ar->Append(static_cast<Atom*>(node)); BaseContainer* bc = description->GetParameterI(DescLevel(POSITIONING_FROM_SP), ar); if (bc) { bc->SetBool(DESC_HIDE, TRUE); } flags |= DESCFLAGS_DESC_LOADED; return ObjectData::GetDDescription(node, description, flags); }
Have a look into the description chapter of the docs. You will find all parameters there you can use for GetDDescription. Best Samir
