Sticky key not being sticky
  • On 01/07/2018 at 09:59, xxxxxxxx wrote:
    Cinema 4D Version:   R19
    Platform:   Windows  ;
    I was experimenting with a CommandData plugin and shortcuts (as sequel on previous question).
    Registering a CommandData using the PLUGINFLAG_COMMAND_STICKY, according to the documentation I should be able to detect the user pressing the shortcut key, and releasing it.
    In both cases CommandData::Execute would be called.
    This, however, is only the case when the user keeps the shortcut pressed long enough.
    If the shortcut is pressed shortly and released, only a single Execute is performed on the "down-stroke". The "up-stroke" (release) is never detected.
    #include "c4d.h"
    // Dummy IDs - for demonstration purposes only
    #define COMMAND_PLUGIN_ID        1999999
    Bool gShowWidget = FALSE;
    class MyCommand : public CommandData
      INSTANCEOF(MyCommand, CommandData)
    public:
      virtual Bool Execute(BaseDocument* doc);
    Bool MyCommand::Execute(BaseDocument* doc)
      gShowWidget = !gShowWidget;
      String txt = gShowWidget ? "On" : "Off";
      GePrint("Widget is " + txt);
      return TRUE;
    Bool RegisterMyCommand(void)
      return RegisterCommandPlugin(COMMAND_PLUGIN_ID, "Testing", PLUGINFLAG_COMMAND_STICKY, AutoBitmap("icon.png"), "Test", NewObjClear(MyCommand));
    // Plugin Main
    Bool PluginStart(void)
      RegisterMyCommand();
      return TRUE;
    void PluginEnd(void)
    Bool PluginMessage(Int32 id, void * data)
      switch (id) {
      case C4DPL_INIT_SYS:
          if (!resource.Init())
              return FALSE;
          return TRUE;
      case C4DMSG_PRIORITY:
          return TRUE;
      case C4DPL_BUILDMENU:
          break;
      case C4DPL_ENDACTIVITY:
          return TRUE;
      return FALSE;
  • On 03/07/2018 at 00:46, xxxxxxxx wrote:
    Hi C4D,
    thanks for making us aware.
    I filled a bug report.
  • On 03/07/2018 at 09:45, xxxxxxxx wrote:
    Thanks for confirming.
    I suppose there's no workaround other than to use a SceneHook and check for keystrokes in KeyboardInput ... as has been mentioned by Andreas here
  • On 04/07/2018 at 00:27, xxxxxxxx wrote:
    Hi C4DS,
    You are right, SceneHook or a ToolData depending on the context is the way to go.
    But as you already discover they got some limitation.
    Hope it's a working workaround for you.
    Maxime
