On 14/08/2018 at 18:20, xxxxxxxx wrote:
When I attempt to use the code
with _localimport('') : import script_two
an error occurs: "name _localimport is not defined"
Perhaps there's a library I need to import beforehand.
(I realize this is a very old post but I'm desperate!)
On 16/08/2018 at 02:20, xxxxxxxx wrote:
Hi Hfeist!
First of all welcome in plugin cafe community!
localimport is a module made by Niklas. So you have to download it from github, then import it to your python script. Niklas also provide a minified version which can be directly used more easily. Note that you should use localimport instead of _localimport
And finally, if you post any code on the forum, please make sure to use [ code] [ /code] markdown.
Cheers, Maxime
