On 28/06/2018 at 07:16, xxxxxxxx wrote:
User Information: Cinema 4D Version: R18 Platform: Windows ; Language(s) : C++ ;
--------- Hello.
I have created a ShaderData plugin in which I use Output method to fill the preview. The problem is that the shader preview appears very washed out in the Material UI. In ShaderData plugin, the preview appears correctly because I have disabled Linear Workflow option from Project Settings, otherwise it's exactly the same. How can I make the shader preview appeared correctly inside the Material UI as well. Is tehre any filter that I can disable via code ?
Thank you.
