On 04/05/2018 at 03:42, xxxxxxxx wrote:
User Information: Cinema 4D Version: R19 Platform: Windows ; Language(s) : C++ ;
--------- My requirement is to create a folder and store some images there. So Is there any SDK API (c++) to create and access the folder. If there is no API, then please tell me the way to create and access the folder. I have created a command plugin where I need to create a folder.
On 04/05/2018 at 03:48, xxxxxxxx wrote:
Have a look in the documentation at GeFile. There is a GeFCreateDir function available, amongst others.
Depending your need you might want to use BrowseFiles to browse the files inside the folder. Finally, have a look at the BaseFile, or HyperFile (depending your need).
On 04/05/2018 at 07:32, xxxxxxxx wrote:
Maybe you also want to check out the manuals on Files.
On 04/05/2018 at 07:45, xxxxxxxx wrote:
Thanks every one.
