On 10/05/2018 at 01:46, xxxxxxxx wrote:
Hi Boony,
I just updated to C4D R19.053 RB224935 and im having the same issue as you had with multiple paths in the C4D_PLUGINS_DIR env variable.
They are network drive paths and one path in the there works fine but multiple paths separated by a semicolon makes C4D crash on startup, any ideas?
Thanks alot, Will
On 11/05/2018 at 04:06, xxxxxxxx wrote:
Hi Willd4553,
Can you tell us if it's crash for any paths? A specific one? Does it crash only with a specific plugin? Does the path exist? Anyway if you want to report a bug report (which in this case is not directly related to the API) please fill this form with the bugreport attached in order to get it checked as soon as possible.
Cheers, Maxime
On 12/05/2018 at 04:58, xxxxxxxx wrote:
Hi Maxime,
Thanks for the reply, no specific path crashes it, it's just as soon as there is more than one in there. Any one path in there and it seems to run fine.
Thanks for the link to the bug report page, i will submit one now
Cheers!
