On 03/03/2003 at 16:36, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.012 Platform: Windows ; Mac ; Mac OSX ; Language(s) : C++ ;
--------- As the user changes a parameter and holds down the shift key I would like to cause the change in value to be 500% greater than normal. The idea is that I want to take the delta change ( I can only evaluate for that within the SetDParameter where I can access the new value and the old value ) and scale it ( or run some arbitrary function on it ) and set the parameter value to the newly created value by the amazing and wonderful widget function. I thought originally that I could set the parameter value in the container in the SetDParameter. Then I realized that the const GeData is what C4D uses to set the parameter to after it leaves the function. Since it is a const I cannot change what the current value will be in SetDParameter. Need info please.
bt
On 04/03/2003 at 23:36, xxxxxxxx wrote:
That is not possible. If you want this level of control you'll have to implement a CustomGuiData with this feature. (This wouldn't be too hard, but you'll have to dig quite deep into the world of custom GUIs and datatypes. The actual implementation would just be a normal edit field. Though I haven't checked if it's possible to change the value during a drag as you describe.)
On 05/03/2003 at 15:44, xxxxxxxx wrote:
Actually got it to work. Pretty cool. Thanks for your thoughts though.
> Quote: Originally posted by Mikael Sterner on 04 March 2003 > > * * * > > That is not possible. If you want this level of control you'll have to implement a CustomGuiData with this feature. (This wouldn't be too hard, but you'll have to dig quite deep into the world of custom GUIs and datatypes. The actual implementation would just be a normal edit field. Though I haven't checked if it's possible to change the value during a drag as you describe.) > > > * * *
