On 28/06/2018 at 16:49, xxxxxxxx wrote:
Could you check this code? I'm not able to see any difference on saved files. Always saving at same compression.
BaseBitmap \*multiBmp = BaseBitmap::Alloc(); multiBmp->Init(1024,1024, 32); BaseContainer dataBc, optBc; optBc.SetInt32(0, (Int32)4); // EXR compressions optBc.SetBool(1, TRUE); // 16-bit for(Float i=0;i<360.0;i+=0.2) { Float a = PI\*i/180.0; multiBmp->SetPen(i,2\*i,3\*i); multiBmp->Line(512,512,512+512\*cos(a), 512+512\*sin(a)); } dataBc.SetContainer(0, optBc); multiBmp->Save("d:/test1.exr", FILTER_EXR, &dataBc, SAVEBIT_MULTILAYER); optBc.SetInt32(0, (Int32)6); // EXR compressions optBc.SetBool(1, FALSE); // 16-bit dataBc.SetContainer(0, optBc); multiBmp->Save("d:/test2.exr", FILTER_EXR, &dataBc, SAVEBIT_MULTILAYER);
On 29/06/2018 at 08:44, xxxxxxxx wrote:
Hello Ahmet,
I suppose you are working in R19? Unfortunately due to internal changes such parameters can currently not be changed. See this thread: [Render settings] File format Options R19 While that's about render settings, it boils down to the same internal issue. I hope this situation will be fixed with one of the next versions.
