On 28/03/2018 at 02:17, xxxxxxxx wrote:
Hi everyone,
I've wrote a python plugin that is currently working normally on a few machines, but have a couple that seem to have problems with windows registries?
Has anyone had this issue or have a solution? I'm assuming that this is not related with Cinema 4D directly but with Windows Registry and Python 2.7.
File "'checkOut.pyp'", line 7, in <module>_<_o:_<_o:p_>_o:p>
File "C:\Users\shawry\AppData\Roaming\MAXON\CINEMA 4D R17_8DE13DAD\library\python\packages\win64\openpyxl\__init__.py", line 29, in <mod_<_o:_<_o:p_>_
from openpyxl.workbook i_<_o:_<_o:p_>_orkbook
File "C:\Users\shawry\AppData\Roaming\MAXON\CINEMA 4D R17_8DE13DAD\library\python\packages\win64\openpyxl\workbook\__init__.py", line_<_o:_<_o:p_>_<module>
fr_<_o:_<_o:p_>_kbook import Workbook
File "C:\Users\shawry\AppData\Roaming\MAXON\CINEMA 4D R17_8DE13DAD\library\python\packages\win64\openpyxl\workbook\workb_<_o:_<_o:p_>_, line 17, in <module>
from openpyxl.wr_<_o:_<_o:p_>_cel import save_workbook, save_dump
File "C:\Users\shawry\AppData\Roaming\MAXON\CINEMA 4D R17_8DE13DAD\library\python\packages\win64\open_<_o:_<_o:p_>_iter\excel.py", line 31, in <module>
_<_o:_<_o:p_>_ from openpyxl.packaging.manifest import Manifest
File "C:\Users\shawry\AppData\Roaming\MAXON\CINEMA 4D R17_8DE13DAD\library\python\packages\wi_<_o:_<_o:p_>_npyxl\packaging\manifest.py", line 41, in <module>_>
mimetypes.init()
File "C:\Program Files\MAXON\CINEMA 4D R17\resour_<_o:_<_o:p_>_les\python\Python.win64.framework\lib\mimetypes.py", line 351, in ini_<_o:_<_o:p_>_/o:p>
db.read_windows_registry()
File "C:\Program Files\MAXON\CINEMA 4D R17\resource\_<_o:_<_o:p_>_\python\Python.win64.framework\lib\mimetypes.py", line 254, in read_windows_registry_
with _winreg.OpenKey(hkcr, subkeyname) as s_<_o:_<_o:p_>_o:p>
TypeError: must be string without null bytes or None, not str
Thank you very much in advance!
Andre
