On 23/03/2018 at 10:38, xxxxxxxx wrote:
User Information: Cinema 4D Version: R18.057 Platform: Windows ; Language(s) : C++ ; XPRESSO ; PYTHON ;
--------- Hello PluginCafe,
I have a weird problem when I am using my shader in a material. I have a time-dependent shader which should recalculate/update on every frame. When I am using my shader in a Displacer everything works fine, and the shader is updated properly. However, when I use the shader in an actual material, it does not get updated at all.
Does anybody now the reason for this?
regards, Florian
On 26/03/2018 at 02:03, xxxxxxxx wrote:
Hello Florian,
can you please be a bit more specific? What do you mean, with "updated properly" and "not updating at all"? During rendering? In the viewport? In case of the viewport, is there a difference, when setting the "Animate Preview" checkbox on the "Editor" tab of the material?
