On 22/03/2018 at 17:19, xxxxxxxx wrote:
According to the documentation, c4d.utils.GetBBox() should return the Center and Radius of the object hierarchy.
However, I'm getting unuseable results. To test:
1. Create a cube
2. Make it editable
3. Move the cube's axis to it's base
4. Add an Expression Tag to the Cube with this expression:
def main() :
obj = op.GetObject()
mp, rad = c4d.utils.GetBBox(obj, c4d.Matrix())
print "(mp: %s, rad: %s)" % (mp, rad)
The output is:
(mp: Vector(0, -100, 0), rad: Vector(100, 100, 100))
Just because the axis has moved doesn't mean the global center point should move.
Expected:
(mp: Vector(0, 0, 0), rad: Vector(100, 100, 100))
Am I misunderstanding how to use this method? If not, any workarounds for making it usable?
