On 13/03/2018 at 07:25, xxxxxxxx wrote:
I'm trying to change a grid filter that only the perspective view.
I was predictable, my code doesn't work. The following code changes grid filter for all viewport.
bd = doc.GetActiveBaseDraw() drawFilter = bd.GetDisplayFilter() cam = bd.GetEditorCamera() projection = cam.GetProjection() if projection == c4d.Pperspective: if drawFilter & c4d.DISPLAYFILTER_GRID: bd[c4d.BASEDRAW_DISPLAYFILTER_GRID] = False else: bd[c4d.BASEDRAW_DISPLAYFILTER_GRID] = True bd.Message(c4d.MSG_CHANGE) c4d.EventAdd()
Could I change grid filter for one of a view or only perspective view? If it possible, where can I get this information in the SDK?
On 14/03/2018 at 06:04, xxxxxxxx wrote:
I'm afraid you've hit a limitation. It's not possible to change the filter for only one view. The display filter is synchronized for all views and the API doesn't allow to circumvent this limitation.
On 14/03/2018 at 06:37, xxxxxxxx wrote:
Hi Yannick,
Thank you tell me this information
Cheers, Makoto
On 14/03/2018 at 09:57, xxxxxxxx wrote:
In fact it's possible to change the filter for a specific view via the UI with the following steps: Options->Configure->Filter->Right-click on a parameter->Make Parameter Local
Unfortunately there's no way to do this with the API.
See the Cinema 4D documentation here.
On 16/03/2018 at 04:43, xxxxxxxx wrote:
Thanks to you I was able to make small scripts. Thank you!!
Cheers Makoto
