Object Plugin: hide child object
  • On 25/02/2018 at 07:34, xxxxxxxx wrote:
    I try to script an object generator that takes a spline as a child, break apart the spline by disconnecting each point and jitter the points of these newly created segments.
    Two problems:
    - The original spline is always visible along with the jittered cloned one I generate and if I hide it when the user moves it apart from the object generator it stays invisible
    - I tried to use c4d.utils.DisjointMesh to break apart the spline in multiple segments but it doesn't work.
    Thank you for your help,
    Francis
  • On 26/02/2018 at 09:27, xxxxxxxx wrote:
    Hi Francis,
    first of all, I'm wondering if the final result of the ObjectData is a spline or a polygon object?
    Usually hiding of input objects of a generator in the viewport is automatically handled, when registering the ObjectData with OBJECT_INPUT flag.
    DisjointMesh() is probably not what you want. At least from your description SendModelingCommand(MCOMMAND_EXPLODESEGMENTS) sounds better fitting to me.
