On 22/02/2018 at 09:40, xxxxxxxx wrote:
Hi guys,
I'm trying to change the ID of a container, is there a good way of doing it please? I've tried using the .GetId() and .SetID() functions without any success. So I am probably using it incorrectly or there is a way of doing this by copying the container and removing the original one perhaps?
Here's some test code:
import c4d from c4d import gui #Welcome to the world of Python def main() : doc = c4d.documents.GetActiveDocument() docBC = doc.GetDataInstance() for id, value in docBC: if id == 12345: docBC.RemoveData(id) print id, value print "---------------------------------\n" MAINBC = c4d.BaseContainer() docBC.SetData(12345, MAINBC) subBC = c4d.BaseContainer() for i in range(0, 10) : MAINBC.SetData(i, subBC) for id, value in MAINBC: if id > 5: print id, value print "---------------------------------\n" if __name__=='__main__': main()
The idea is to change the id for the baseContainers to ID - 1.
Hopefully this will make sense, but let me know if you need more info.
Thank you in advance!
Andre
On 23/02/2018 at 08:57, xxxxxxxx wrote:
Hi Andre,
first of all there's a difference between the ID of a BaseContainer (GetId(), SetId()) and the IDs used for the stored data (e.g. SetData(id, data)). The ID of the BaseContainer itself can be used to easily identify a container. For example you could set the ID of your MAINBC to a unique plugin ID.
By the way, when storing something in Cinema 4D's BaseContainers (like in this case the document settings), you should use a unique plugin ID to store your custom container, to make sure, you don't collide with anything else.
Then there's something special about the settings of a document. These are a bit distributed, so you'd rather use GetDocumentData(), SetDocumentData() and/or GetSettingsInstance() instead of doc.GetDataInstance().
And then there's the part of your question about setting a container's ID to -1. I'm not sure, if you are talking about the container ID or some ID of the contained data, nor do I see, where you try to do this in your code. Maybe you can explain a bit more, what you are actually trying to achieve?
Even though it's in our C++ SDK documentation and only contains C++ code snippets, I think, the BaseContainer manual could also help to get a better understanding.
On 26/02/2018 at 00:22, xxxxxxxx wrote:
Hi Andreas,
Thank you for your help!
first of all there's a difference between the ID of a BaseContainer (GetId(), SetId()) and the IDs used for the stored data (e.g. SetData(id, data)). The ID of the BaseContainer itself can be used to easily identify a container. For example you could set the ID of your MAINBC to a unique plugin ID. By the way, when storing something in Cinema 4D's BaseContainers (like in this case the document settings), you should use a unique plugin ID to store your custom container, to make sure, you don't collide with anything else.
Fantastic! To be honest I am using the unique PLUGIN ID, what I wrote was just as an example. But the idea is similar.
Ah ok! I see... In the examples that I saw through the forum I saw the doc.GetDataInstance(), thinking that it would be the best way to go. Appreciate you pointing it out!
Apologies! That's my bad, as I didn't explain myself correctly. I'm trying to change the id of the contained data. In the example I've added, the MAINBC will contain 10 pieces of data with ID from 0 to 9. What I like to do is if I remove one of values of the contained data, the ID values that are bigger than the ID removed be subtracted by 1. If the data with ID 5 is removed, then: 6 <c4d.BaseContainer object at 0x0000000021858260> 7 <c4d.BaseContainer object at 0x00000000218585A8> 8 <c4d.BaseContainer object at 0x00000000218583E8> 9 <c4d.BaseContainer object at 0x0000000021858420>
will become: 5 <c4d.BaseContainer object at 0x0000000021858260> 6 <c4d.BaseContainer object at 0x00000000218585A8> 7 <c4d.BaseContainer object at 0x00000000218583E8> 8 <c4d.BaseContainer object at 0x0000000021858420>
Hopefully this will make more sense!
Thank you! Will have a look!
I appreciate your time helping me out.
On 26/02/2018 at 02:22, xxxxxxxx wrote:
Well, as long as the data type stored at a given ID does not change, it could be as easy as this:
# first overwrite, beginning with the "to be removed ID" all entries with the following one for i in xrange(idRemove, idMax-1) : bc[i] = bc[i+1] # finally remove the, now duplicate last entry with last ID bc.RemoveData(idMax-1)
On 26/02/2018 at 02:33, xxxxxxxx wrote:
Ahhh! I see what you did. Fantastic!
That gives me a better insight on how to correctly change the container's data.
Thank you very much!
Have a rest of a great day!
