On 20/02/2018 at 14:18, xxxxxxxx wrote:
Hi guys,
Maybe a really simple questions. Normally when I need to excess a value from an object I copy the text field inside the console and do a print command.
Now I need to excess the range start and range end value from the Redshift Proxy object. (see image below) But you can't drag them into the console because there in a tab. (proxy/animation)
You can also access them from the Xpresso Editor.
There must be a way right?
Hope someone has an answer:)
On 21/02/2018 at 02:18, xxxxxxxx wrote:
Hi JW Zegelaar,
Most of the time, when you need to access individual parameter from a CustomGui you can right click on this parameter (File in your case) => User Interface => Show Subcontainer. Then you will be able to drag/drop in the console each parameter.
Which will give us
op[c4d.REDSHIFT_PROXY_FILE,c4d.REDSHIFT_FILE_ANIMATION_RANGE_START] = c4d.BaseTime(0.5) op[c4d.REDSHIFT_PROXY_FILE,c4d.REDSHIFT_FILE_ANIMATION_RANGE_END] = c4d.BaseTime(1) c4d.EventAdd()
On 22/02/2018 at 13:26, xxxxxxxx wrote:
Perfect! Is this exactly what I need!
Thanks you so much!
